Page 207 of 222 FirstFirst ... 107157197205206207208209217 ... LastLast
Results 2,061 to 2,070 of 2211
  1. #2061
    Oct 2014
    Fitted a GFB DV+ to replace my old rev C valve.
    Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
    Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
  2. #2062
    Aug 2016
    Adelaide, South Australia
    Got my centre console tray in the mail. very handy.
    2008 VW R32 - Milltek Catback - APR
  3. #2063
    Aug 2016
    Not too much activity around these parts anymore it seems! Here is my shiny new hazard light button. Ignore the dust :s
  4. #2064
    Jul 2007
    Brissy
    Did a 6 month oil change this week.
    LiquiMoly TopTec was on clearance at SuperCheap a while back so I got some of that. I'm hoping it will not burn off as quick as the Castrol oil does. I used 2 litres in 6 months, 9,500km.
    Also decided to try an intake clean too.
    Well the smoke and high revs was a bit of fun but it killed the spark plug on cyl 2. Not really impressed by this. At least spark plugs have come down in price. Now only $14 each, were $30+ last year. Repco still wants $35 each after Autoclub discount however
    I changed just the 1 plug and all was good for 300km until the misfire returned. So I went and got 3 more plugs and changed them out.
    That is when I saw the connector to the coil pack on cyl 2 was not quite seated. VCDS scan showed
    004952 - Cylinder 2 Ignition Circuit P1358 - 004 - Open Circuit - Intermittent
    I should have scanned first
    All 4 coil connectors have broken clips so I have introduced 2 screws to hold the connector rail in place.
    So let that be a warning, if you do an intake clean with a spray be prepared for spark plug failure, maybe put in some old ones during the cleaning process.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  5. #2065
    Mar 2009
    Quote Originally Posted by JustCruisn View Post
    I can't see on Tapatalk but what car do you have?
    What LiquiMoly TopTec you using? 5w30 or 5w40?
    1L every 5,000km (or close enough) doesn't sound too bad to me these days! lol. I've switched to 5W40 to reduce the oil consumption, still consumes but less than 5W30. My 5W40 is still VW 502/505 spec.
    What spark plug you using?
    And what is this intake clean method are you referring to? If it damages your plugs, you may as well do it when you're going to replace them.
    My mechanic threw out my 15k old spark plugs at the 120k major service The worst part was I asked him to change the plugs at the 105k service (as I was getting the timing belt replaced at 105k) but he didn't check the log book or his records so changed them again at 120k. I was less than impressed as he did both services.
    Sent from my SM-G930F using Tapatalk
    MY07 Red GTI 3 Door
  6. #2066
    Jul 2007
    Brissy
    Car is 2.0T jetta
    Oil is toptec 4200 5w30. I only use 504/507 oil.
    Plugs NGK PFR7S8EG
    Cleaner is liqui moly petrol decarb Liqui-Moly Petrol Engine Intake Decarb - 366g - Supercheap Auto
    Sent from my LG-D802T using Tapatalk
    MK4 GTI - Sold
  7. #2067
    Mar 2009
    Where can I find instructions on the intake clean?
    Try 5w40 if you wish to reduce oil consumption, 502/505 is still approved.
    MY07 Red GTI 3 Door
  8. #2068
    Aug 2016
    Capalaba, Queensland
    Learning a fair bit about the MK5 GTI and doing the work myself.
    Received advice from GFB.com.au regarding the diverter valve. The original was a better design than the revision D, though the rubber splits on the original. Pulled the original out and replaced with the GFB modified diverter - WOW! Massive difference to the lag and way more responsive. Just have to replace the brake booster with check valve (another common fault) so that the PO171 code is fixed (system bank too lean).
  9. #2069
    Aug 2016
    I did mine also. Huge difference eh..
  10. #2070
    May 2013
    Mine has gone in for a carbon engine clean and fitting the stock DV back on. Currently have the GFB + on
