Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 59
Thread: SuperPro Supaloy Control Arms
  1. #41
    Oct 2010
    Melbourne, VIC
    There's a twisting motion at the rear of of the control arm which beats the snot out of a polyureathane bush in this location. They work well when the motion is pure rotation.
    Resident grumpy old fart
  2. #42
    If you bought ours (With the black bushes) then we offer a limited lifetime warranty to the original purchaser.
    We use a harder duro than the regular Superpro ones. We just did a strip down & inspection on our stage 4 Golf & they look like brand new after 6000 race miles.
    Take them back to your original supplier & ask for warranty.
  3. #43
  4. #44
    Oct 2009
    Mitchelton, Qld
    Guy, do you just sell the bushes then? Front and rear and hence could you fit your bushes to my LCAs?
  5. #45
    No Don - sorry, as the arms also have the matching component (the poly then round metal bush) cast onto the arm - we don't do them separately.
  6. #46
    Oct 2009
    Mitchelton, Qld
    Well that does suck then!!!
    Guy, would you class this much amount of movement in the rear bush of the lower control arm normal/acceptable (also note how much the wheel moves in the background!!!).
    https://www.youtube.com/watch?v=5y5g...ature=youtu.be
  7. #47
    Have your email Don - needs to be checked out, its not the rear bush at all, its something else.
  8. #48
    Erskineville, NSW
    I thought the rear bush controlled the radial movement (side-to-side, up, down) & the front bush controlled the fore/aft movement?
    While prying it with the bar it would be nice to see what is happening at the front part of the LCA.
  9. #49
    Oct 2009
    Mitchelton, Qld
    Prestige and Performance looked at it today. Agreed front bush was no good. They said bring it back next Wed and they'll sort it out from there (not sure what that means but we'll see come next Wed I guess).
    Thanks for your help Guy. Greatly appreciated.
  10. #50
    Oct 2009
    Mitchelton, Qld
    Prestige replaced both front bushes (left and right side) today. Apparently there's a new front bush design.....surprise surprise. Car handles so much better now. Just need new tyres and rims now!!!!
