Not sure if it's too late for you, but I did this to mine this evening.
Under the two grab handles there is a single phillips head screen in each, if you open the hatch and stare up into the grab cavities in the plastic trip you will see them there.
Once they are removed, level the edges gently away from the metal from both sides and once you can lever enough, gently but firmly pull the plastic cover down and away from the boot hatch.
It may seem brutal at first, but the metal clips will indeed pull away with a loud 'clicking' sound. There are a a few so just keep levering away until the trim comes away completely.
Dino.
SQ5 V6TDI | 911TT | Polo 6C
