Does the noise happen
- when moving
- when stationary
- does it change with vehicle speed
- does it change with engine speed
- does it change dependant on selected gear
- which gear box do you have
Hi All,
I have a 2008 golf tdi with 129,00 kms on the clock and recently had a major service and timing belt changed.
On 3 occasions the noise occurred after I had been driving for about 10-20 mins turned the car off to duck into the shops quickly, restarted and went to take off. The noise is pretty loud and sound like it's coming from the underside of the engine( but not100% sure)The noise doesn't happen when I turn. When it has occurred I pull over turn the car off and sit for about 5 mins and restart then the noise disappears. The noise hasn't been constant and has happened kind of randomly.
I've done a general search on google of what it could be and it states that it might be bearings, cv joints or differential fluid.
I have no idea about cars but would greatly appreciate any ideas of what it might be.
Thank you!
- when moving
- when stationary
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
