Results 1 to 3 of 3
Thread: R32 cluster into GTI/Jetta
    Apr 2008
    NSW
    As per title, I'm curious as to whether a MK5 R32 dash cluster will fit the GTI/Jetta. Will the MFD display work? Because on some clusters, I have seen the MFD with a line in the middle, making the display look like 2 separate displays. Mine is just the one large rectangle....
    Also, where would one source an R32 dash cluster?
    Jan 2007
    brisbane QLD
    the MFD will work but the hard part is coding the new cluster (immoboliser) - you'd need a very friendly dealer!
    You might also have a lot of difficulty with the tacho signal - Internally its wired for 6 cylinders.
    I suppose you could install an R32 engine - that would solve the problem
