Results 1 to 10 of 12
Thread: FSI oil drain tool instructions
    Mar 2009
    Hey,
    Purchased one of these tools because I was sick of cleaning up the mess when changing the oil filter.
    after draining the sump for 10 mins, I used the tool and drained the oil filter housing for 5 odd mins.
    There were still some oil coming out but Ix thought it should be long enough. Plus you a little oil left in the housing is ok as it shouldn't spill.
    Undid the housing and a ****load of oil splashed out. It seemed draining the housing using the tool for 5 min did jack all.
    My question is how long does it take to drain the housing so it doesn't spill?
    I would like to punch the engineer who designed a paper oil filter housing up side down in the face.
    My BMW and Volvo oil fiter housing is accessed from the top of the engine. Undo oil filter housing cap and place in a plastic bag. Simple, quick and no oil spills.
    Sent from my SM-G930F using Tapatalk
    MY07 Red GTI 3 Door
    Dec 2008
    Sydney/Canberra
    I don't use the tool. I just push the valve up, and over to the side to hold it there, and let it drain by itself.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2009
    That's what I did before but is messy.
    How long do you let it drain for before removing the housing?
    MY07 Red GTI 3 Door
    Dec 2008
    Sydney/Canberra
    Until it stops.
    They don't hold much, maybe 250ml.
    '01 Beetle 2.0
    Mar 2009
    That's what I thought.
    The interesting thing is I'm sure I drained at least 250ml and a crapload of oil still spilled out of the housing.
    MY07 Red GTI 3 Door
    Dec 2008
    Sydney/Canberra
    I did one today, seemed like all the others I've done.
    '01 Beetle 2.0
    Adelaide hills, SA
    I've never bothered to get one.
    The cost of the tool = a lot of brake cleaner (degreaser), therefore it's quicker and easier just remove the plastic cup and wash afterwards.
    Jul 2007
    Brissy
    I just make sure the bucket is in the correct position.
    It let it go until I've replace things like air filter or spark plugs. ie Do something else while it drains.
    Spray a shed load of degreaser once its replaced.
    Also a large cardboard box folded flat makes a good spill catcher.
    As the say, a watched oil filter never drains
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2009
    I would have thought you of all people could amortise the cost of the tool. Lol
    I bought the tool so to reduce the mess in my garage (and my hands).
    Quote Originally Posted by JustCruisn View Post
    Next time I'll get a clamp rather than hold the hose and let it drain for the same amount of time as the sump.
    MY07 Red GTI 3 Door
    Adelaide hills, SA
    Quote Originally Posted by Johnbu View Post
    What's the point to use the tool that slows you down and you still have to clean up after using it.
