Mine has latest firmware but when it was the original 2840 I loaded 18 gig of music onto the hard drive using a 32 gig SDHC card no trouble but took a fair while to do it.
The cards should be formatted as FAT 32 and unit should accept a 32gig vers I use 32gig cards for my video camera Dashcam and RNS for music Just easier to have all the same Have Fujitsu, Bauhn and Samsung cards and have never had any trouble with them not working in any of my units DONT BUY CARDS OFF EBAY 99% are fakes. Most good Class 10 32GB cards would be over $50 if genuine
SD and SDHC are really just different capacity cards as per this article from a photographer
First off you might be asking yourself, ‘What is SD?’ SD stands for Secure Digital. SDHC? Secure Digital High Capacity. And SDXC? Secure Digital eXtended Capacity. Other formats include miniSD and microSD but your DSLR will not accept these. There is no quality/security difference between these three formats. Cards labeled SD have capicity up to 4GB, SDHC usually have a capacity of 4GB – 32GB. SDXC formats can be very large and expensive. I am going to recommend that everyone stick with SDHC format. These cards have more than enough storage.
You will see a Class 2,4,6 or 10 on SD Cards. This is the speed rating which measures maximum transfer speed for reading and writing images to and from a memory card, expressed as megabytes per second. However, video doesn’t need as big a data pipe because the video format is a smaller “fixed stream” that uses only a portion of the data pipe.
