Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 88
Thread: dArK5hAd0W's Timeline
    dArK5HaD0w's Avatar
    dArK5HaD0w is offline Volkswagen Fanatic
    Jul 2010
    Quote Originally Posted by Mysticality View Post
    DRL dim is awesome, as are free cornering fogs.
    If you don't enable both boxes, fogs will only come on with steering. If both boxes are enabled, they'll also come on with indicator.
    Bloody handy.
    actually they're both independant of each other.
    if u have cornerning foglights enabled, it will work based on steering input & speed below 40km/h - regardless of the indicator being on or not. provided low beams r activated.
    it doesn't care if the DRL dimming feature is enabled.
    same control modules for both, but no dependancy.
    My Octavia RS MY11; 2.0 TSI; DSG6; Liftback; Sprint Yellow; AFS Xenons; Columbus (RNS510); Fr & Rr Parking Sensors; Tints; 18" Neptunes; Bluetooth GSMIII (9WZ); Cornering Foglights; DRL Indicator Dim; CH/LH with Foglights; Eibach ProKit; Footwell Lighting; 402Nm of APR goodness;
    Mysticality's Avatar
    Mysticality is offline Volkswagen Fanatic
    Bowral, NSW
    I meant both cornering foglight tickboxes.
    There are two that The_Hawk and I found whilst exploring VCDS.
    dArK5HaD0w's Avatar
    Jul 2010
    there's two?
    the one i did was "Control Module > [09] Central elec / Coding / Long coding helper / byte 14 / bit 5".
    didn't have to check any others.
    oh well......
    Bowral, NSW
    I know there's one somewhere.
    When you turn the indicator on, and slow down to under 40, the fog comes on.
    After changing my BCM, it doesn't do it anymore.
    I wanna get this changed. Might give the dealership a list, at the 15,000 service. Its coming up soon. :S
    dArK5HaD0w's Avatar
    Jul 2010
    so the springs were installed today - am happy with the finish. the ride & the look.
    eibach pro-kit (p/n: E10-79-004-02-22; Skoda p/n: ZGB1Z3071676)
    admittedly the front has dropped 30mm, while the rear has dropped 20mm, as expected.
    measurements (with full tank) from the ground to the top of the wheel arch:-
    before front: 680mm
    before rear: 690mm
    after front: 650mm
    after rear: 670mm
    maybe the rears r yet to settle in.
    here r some grainy iphone pics from inside my garage. i got home late, so no good pics.
    speakin of getting home late, i noticed my xenons need to be realigned. they're projecting much less. since the frontend has dropped 30mm, this changes the throw of the low beam distance.
    even the skoda accessories website states that headlights need to be realigned after fitting these.
    so now i gotta book it in with the dealer n get it done.
    bluefrog's Avatar
    bluefrog is offline Volkswagen Enthusiast
    Jul 2011
    Burwood, VIC
    Todd likes this
    - MY11 GOLF R | revo | RB | man | SPM DP | Autotech HPFP | 18x8 Rays VR G2's | Carbonio | SB | whiteline ALK
    - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 235/40 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
    -- facebook.com/toddzy.vrsshagwagon --- my build thread --
    dArK5HaD0w's Avatar
    Jul 2010
    Quote Originally Posted by dArK5HaD0w View Post
    spoke to the vw service centre, and the earliest they can do it for me is april 13th
    i wonder if canberra vw centre (cvwc) can do this job?
    didn't think of them till now. will give them a buzz trow n find out.
    dArK5HaD0w's Avatar
    Jul 2010
    i'm selling my original springs.
    link here for those interested.
    bluefrog's Avatar
    Jul 2011
    Burwood, VIC
    hmmm, methinks I might need to do this!
    dArK5HaD0w's Avatar
    Jul 2010
    here is a pic of the front self-levelling sensor. its on the passenger side. u can see it with the wheels turned to the right on full lock.
    notice how the arm is on an angle. thanks to the 30mm lower ride height up front, the sensor arm is compressed/bent more than its usual postion.
    the rear sensor arm is not compressed as much because it was a 20mm drop.
    but because there was already a 10mm difference between front & back before lowering, the end result is a 20mm difference between the two now. making the sensors think the front of the car is constantly on a "20mm" high speed hump.
    if the dealers can't realign the headlight the conventional way, the only other option would be to pop the arm off, and shorten it.
