Page 21 of 35 FirstFirst ... 11192021222331 ... LastLast
Results 201 to 210 of 345
Thread: 1980 B1 Passat Project
  1. #201
    Peter Jones's Avatar
    Peter Jones is offline Super Moderator VWwA Super Moderator
    Boronia VIC
    Quote Originally Posted by IH8 View Post
    Is that a Uniflow air filter? Standard Solex carb. (same inlet size as Golfs)?
    That's a Ramflo filter sitting atop a Weber DCD carb.
    Thanks for the kind words
    Pete
    79 B1 Passat Dasher Project
    12 Amarok
  2. #202
    Boronia VIC
    Righto, knocked over the booster conversion today.
    I'm not going to write up a "How to mod a MK3 booster for one of only 3 remaining B1 facelift Passats thread" You can read about it here instead.
    The usual suspect.
    Master cylinder off, and looks like it's long overdue, the booster is full of brake fluid!
    Heaps came out when I drained it.
    12 Amarok
  3. #203
    Boronia VIC
    It's worth pointing out here that Passats are a bit different here and this model in particular.
    The transverse rod that actuates the brakes runs inside the firewall here's a few pics of the mechanism.
    Much the same end as the MK1 Golf booster really.
    12 Amarok
  4. #204
    Boronia VIC
    Firewall cleared off.
    I trial fitted the MK3 (Seat Cordoba) booster about now and it fitted up fine despite being a bit bigger in diameter.
    Here's a Seat Cordoba booster ready to be modified.
    The Passat booster has an adapting collar on it which needs to be opened up a bit to sit over the neck of the MK3 booster.
    OK classic PJ style MK1 booster mod now.
    Chop off the ball end.
    Turn a M10 x 1.5 thread down the shaft.
    Of course you measure the old booster's clevis height and set up the new booster the same.
    Before you know it, you've got a modern booster for your B1 Passat.
    12 Amarok
  5. #205
    Boronia VIC
    Installation is the opposite of removal
    New booster just bolted straight in.
    Now the Cordoba m/c only has 2 ports so I'm using a couple of T pieces along with a pair of the much sought after 16v Scirocco portioning valves for the rears.
    Leaves me with a couple of gaps to fill in the plumbing so I made a couple of short lines up.
    This is a really neat flaring tool I picked up from eBay, Awesome quality and a perfect flare every time.
    Cheapo bender to form the pipe up a bit.
    And all together again.
    The fluid reservoir is a bit tall, I can't quite get the level sensing cap on there but it clears the bonnet OK with a MK1 reservoir cap on it.
    12 Amarok
  6. #206
    roccodingo is offline Volkswagen Fanatic
    Perth. WA
    Looking good Pete, love how the brake relay rod is inside the car, just to make it even more of a headache..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  7. #207
    Preen59's Avatar
    Preen59 is offline Ultimate Dubber
    Jun 2006
    Orange NSW
    Way to go, Pete. Nice, clean and tidy job.
    APR Tuned | KW Suspension | Weitec Suspension | INA Engineering | Mocal Oil Control |
  8. #208
    Jarred's Avatar
    Jarred is offline Dub Crazy
    Jun 2007
    Eastern Suburbs Melbourne
    Good work Pete! top notch as usual!
    i like volkswagens
  9. #209
    DubSteve's Avatar
    DubSteve is offline No Dub Steve
    Sep 2006
    Australia?
    Once again Pete fantastic work mate, good to see its almost finished
    Project 504
    Slammed Distribution
  10. #210
    Boronia VIC
    Got two new front seatbelts and fitted them today.
    Fitted up a brake switch off the pedal too, there's a hole already there for the switch.
    Next is the instrument cluster.
    12 Amarok
