Hi
My car started loosing all of the coolant as it reaches operational temperature. It suddenly just started today. I have located plastic part from where coolant is running down and steam coming out too.
Please help me identify what is this part by pictures.
Thanks in advance.
3.jpg - Google Drive
2.jpg - Google Drive
1.jpg - Google Drive
Vagcom codes are
VAG-COM Version: Release 409.1-S
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
Controller: 06A 906 033 AF
Component: SIMOS33 1.6l 2V 00AT4083
Coding: 00033
Shop #: WSC 01271
WVWZZZ1JZ2W481205 VWZ6Z0A3820669
2 Faults Found:
16706 - Engine Speed Sensor (G2: No Signal
P0322 - 35-10 - - - Intermittent
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 35-00 - -
Readiness: 0010 0001
Address 02: Auto Trans
Controller: 01M 927 733 JH
Component: AG4 Getriebe 01M 4830
Coding: 00000
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes
Controller: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 01271
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1J0 920 806 C
Component: KOMBI+WEGFAHRS. RB8 V17
Coding: 03722
Shop #: WSC 00000
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01271
Address 46: Central Conv.
Controller: 1C0 959 799
Component: 1Z Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 01271
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-00 - Implausible Signal
End --------------------------------------------------------------------------------------------------
