Another symptom is no check engine light at all... EPC light is always on.
Thanks MK1 I have replaced the crank sensor with no change, also have unplugged both cam and the maf sensors to trick it to start. I am going back over the electrics tonight to see if I have missed anything.
The other thing that it sounds like is the immobiliser.
Mmmmm I did have a thought about that, however I have no idea how to check that Bora Sport.
I did some tests, ECU has no power to main pins I think 3 and 24, not sure what the other ones I checked were, relay 428 under the bonnet has no power they ground on the relay and with the ecu disconnected one of the main large pins has ground... I am unsure what's the go there, but applying ground power the the relays ground pin gets the relay to work, although it still wouldn't start, I had to stop as it started raining quite heavy, so that's as far as I got.
So questions, how do I check immobiliser?
How does the ECM get power? I read that the 428 relay is actually controlled by the ECM? How? How else does the ecu get power?
I also noticed last night that my passenger door won't lock or unlock with the key or the internal button, it had always worked, unsure if this is a symptom...
Just to recap, all fuses are getting power to both sides, fuel pump relay under kick panel appears to work...
