Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 4motion clutch issues
    Mar 2010
    Lesmurdie
    Quote Originally Posted by TonyG View Post
    "Can of worms" time:
    Should I get the cheaper single plate clutch kit? Surely a VR6 runs more smoothly than a 4 or 5 cylinder engine?
    If its your daily driver i would advise against it. I get a lot of gearbox chatter when i went to a single mass.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Nov 2017
    Dunlop, ACT
    I agree. So, I am looking for an OEM clutch and flywheel kit to replace the heavily glazed and worn one that I have removed.
    To finally remove the gearbox, I dropped the subframe [4 bolts], then unbolted the steering rack.
    Since I will be removing the flywheel, I will replace the main oil seal as well.
    Can anyone suggest parts sources?
    Thanks...
    How did you go?
    How many k's has your car done?
    Paul
    Oct 2023
    Ocean grove
    Tony did you get bolt out of shaft or did you drill it out ? My bolt is in so tightly I can feel the 6mm hex starting to turn inside the bolt and strip. Someone must of been in here before. As it’s very tight. I don’t want to snap it
    Quote Originally Posted by Xavier123 View Post
    Rounding out the head is way more likely than snapping the bolt.
    You are better shocking it than trying to turn with a ratchet or something. I usually just use an impact gun and out they come.
