After top grade Varta, the BOSCH S5 is a good choice. You can also fit a bigger battery there.
T5 FAQ and How to THREAD (up to August 2009).
Looks like the original battery is in the way out in my van.
What replacements have people been putting in these vans here in Aus?
How is 5 years for the original these days? (I had 8 years from the original in an '82 T3.)
Thanks folks.
Sent from my SM-G900I using Tapatalk
2012 132kw T5.1 TDI DSG 4Motion LWB Transporter, locking rear diff. Macron Campervan conversion. ECB bullbar. Milford towbar and rear light protector. Seikel Desert HD 30mm lift kit.
Thanks Transporter.
(I put a compressor next to the battery so there is no room at all for a larger battery. Didn't even THINK of the possibility at the time. )
In 2013 I replaced my original 2010 battery with this on the advice of my auto elec - Platinum Power 2000 N55HMF 550CCA 100RC for $143
No problems 3-1/2 years later
__________________________________________________ __________________________
VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
Maybe I need to be looking for a new auto electrician as well
Had hoped I didn't need to double check a paid professional.
Haven't noticed any problems since then. What could the effects of this be?
Cars like that need AGM batteries and buying one with higher CCA will ensure it will last longer. For your 2012 T5 these 2 are good, 730 and 760CCA. The higher spec one sells at the moment for $199 at SuperCheapAuto, but confirm again as well as the size too.
MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
Thanks for that.
An optimist would say With every negative there must be a positive at the other end.
