Could be a warped pressure plate, or heat spots on the flywheel.
Hi, my old T4 (98 2.5L petrol) developed a new problem (?) today, sitting at a set of lights foot on clutch and in gear ready to go when I noticed a pulsing sensation in the pedal - almost like it was trying to move forward with each pulse. Any ideas?
2017 T6 2lt Diesel Manual
The only person to get everything done by Friday.......was Robinson Crusoe.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Yeah........that could be quite a few things.
Try pumping it before moving it into gear........to rule out hydraulic..............getting any noise?
My thrust bearing failed before any part of the clutch after nearly 300k............but that was a 2003 model.
2018 Crafter Runner
T5.2 6sp manual.
Thanks for the quick replies guys. I'll try pumping it today as that seems an easy first attack. Is the clutch fluid shared with the brake fluid reservoir? I remember looking for it once and couldn't find a separate reservoir. As far as noises go I couldn't say that I heard anything that seemed related, BUT my ears aint what they used to be. I remembered after I posted yesterday that a couple of weeks ago it was almost impossible to get into first after sitting for a week or so without being used, but once driven it came good. It's only done 190k....
By any chance you were leaning a bit on the gear stick? Is there pulsation when your hand is not touching the gear stick?
Hi, pulsation was felt through the pedal (whilst stopped at lights), I wasn't touching the gear stick until after I moved off and changed gear and the pulsation wasn't felt then. It was only felt when stopped and each time it seemed a bit less.
