Results 1 to 10 of 11
Thread: Speedo
    Oct 2011
    Speedo
    Is it possible to get a speedo altered to allow for bigger wheels
    Most people changing rim size will change tyre profile/size also to keep the rolling circumference/diameter the same (and hence no need to change the speedo).
    I'm not sure it is legal to fit larger wheels/adjust the speedo. Though I believe there are some VCDS options to make adjustment to the speedo if you need to.
    Adelaide hills, SA
    If it's the earlier T5 then the distance impulse no. can't be changed in VCDS. Though you could experiment with modifying the VSS signal from the gearbox.
    Oct 2011
    Any good vw specialists in Melbourne who you could recommend or is it a dealer thing.
    Pacific Paradise QLD
    Wheel diameter more than 25mm over largest stock size is illegal.
    Check your speedo against a GPS and you will probably find its fast by up to 7kph.
    Our Polo is 7kph fast at 100kph and to get it accurate would take a wheel diameter 40mm larger which apart from being illegal would overgear it so far it might not move very fast LOL
    Checked this with GPS and with secret menu readings.
    Adelaide hills, SA
    Quote Originally Posted by Leespe View Post
    Not even dealer will be able to do it.
    Mt Cotton
    Best option is to get a GPS as suggested and do some open flat road driving then note the difference , I imported some heads up displays that give speed readings from the ECU strange thing is I get three different readings Speedo will say 104 k the GPS will show 100 k and the heads up displays 98 . Its very hard to get a totally accurate reading from any car speedo if you change tyre wheel combination then allowances for worn tyres has to factored in that's why most car speedos will give a higher than actual speed .How accurate is the speedo
    . Its very hard to get a totally accurate reading from any car speedo if you change tyre wheel combination then allowances for worn tyres has to factored in that's why most car speedos will give a lower than actual speed .How accurate is the speedo
    Speedos are required BY LAW to give a HIGHER THAN ACTUAL READING
    The ADR says it can be up to 10% fast <> 4% but NOT less than actual.
    Here is the ADR rule 18/03 http://rvcs-prodweb.dot.gov.au/files/ADR%201803.pdf
    Thought we sorted all this out in the other thread LOL
    Mt Cotton
    OOP"s got that the wrong way around sorry meant to say higher than shown not lower apologies .
    An easy mistake and I think half the drivers in Queensland think the same they speeds that they drive at LOL
