Originally Posted by
drivesafe
Hi Bryn and this is just one of many deliberately misleading “advertising facts” put out by those selling DC/DC devices
This 80% is just a number plucked out of thin air and has nothing to do with any form of reality.
If you drive long enough, your alternator will easily fully charge your auxiliary battery. It all depends on how long your drive for, as to what SoC the battery is in at the end of the drive.
A short drive might have the battery up to just 30% SoC, while a long drive might have the battery over 95% SoC.
So if you had an auxiliary battery in a low State of Charge ( SoC ) and you only drove long enough to get the auxiliary battery to 80% SoC while charging it from your alternator.
Then if you had the same auxiliary battery, at the same low level of charge, and you drove for the same length of time, but this time you were using a DC/DC device to charge the auxiliary battery, you would be very lucky if the battery got to 50% SoC.
This is one of the FACTS these sellers very conveniently forget to tell you, a DC/DC device will take at least twice as long ( twice as much driving time needed ) to do what an alternator can do and with an auxiliary battery like an Optima, with it’s a very high recharge current capability, a DC/DC device would take 4x as long to recharge it over what your alternator can do.
Not talking about on the open road, this is about driving around town, particularly in heavy traffic conditions.
In STOP/START events, a DC/DC device will cause the cranking battery to discharge faster while the motor is off and will mean the motor will be turning on more often. This is both an additional strain on the cranking battery and the starter motor, meaning short operating life spans for both, plus the continual need to restart of the motor early, while stopped in a STOP/START event, will use up more fuel.
If you have a portable solar panel and only use it while you are camping, then yes, this is an advantage.
But if you have your solar panels permanently fixed to your vehicle, while not that commonplace, but using a DC/DC device means you loose the additional charging capability of the solar while driving.
But if you have a separate solar reg, then you now have even faster charging while driving.
I prefer to be honest when I supply data and with some battery types, in a worst case scenario, it would be exactly as I posted up on my website, but as I posted above, with some high current handling batteries, like new Lead Crystal batteries, you would easily charge them in half the time a DC/DC device could and an Optima, it would take around a 1/4 of the time to charge the battery.
And note, these are REAL facts that have been proven in real world use.
BTW, there is no such thing as “STRESSING” an alternator.
You can not overload an alternator, by their very design of how they operate, they protect themselves from current overload. Just one more myth.
