Originally Posted by
Sunny43.5
First thing with the loose object would be to remove the pollen filter under the dash LH side , once the filter is out you can reach up into the main intake space and check for a hitchhiker . I know mine used to make some strange noises turned out loads of leaves had acumlated in the airbox . Do the rear lights come on when the tailgate or side door are opened as there are multiple fuses for the rear lights so you may find that there is more than one fuse for them . Did you check the sticky thread for T% essentials and fuse locations , take your pick from around 120 of the mongrels .
