BoschAutoShop
Results 1 to 4 of 4
Thread: DIY Short Shift
    dub be good to me's Avatar
    dub be good to me is offline Volkswagen Fan
    Sep 2008
    Fitzroy, Melbourne
    DIY Short Shift
    Not sure if this has appeared on here yet.
    The link below is an explanation on how to build a weighted short shift kit for your Mk1-3.
    http://www.4crawler.com/Diesel/ForSa...tLinkage.shtml
    76' 2dr Kjet
    pepperwhite's Avatar
    pepperwhite is offline Volkswagen Fan
    Mar 2006
    brisbane
    I purchased from a short/weighted setup from that guy. Was cheap from memory and the shifting is great.
    Recommend getting the new bushings too, now its better than new.
    Sep 2008
    Fitzroy, Melbourne
    Ok, I finally got around to doing this... and it is awesome
    I did a custom job, slightly different to in the link. I just cut a piece of steel bolted it on to the throw arm (with a couple of rivets for good measure) and drilled two 8mm holes (same size as joining rod to eliminate slop), and whacked it on.
    So simple, so effective.. highly recommended.
    While I was under there I noticed the rubber ball on the lever (pic of new one below) had worn completely off!
    If any one has a good one of these for sale PM me..
    (also looking for bushing set, but will order from OS if unavailable)
    76' 2dr Kjet
    Jarred's Avatar
    Jarred is offline Dub Crazy
    Jun 2007
    Eastern Suburbs Melbourne
    Tim (golfworx) had a set of bushes made up out of brass. apparently they're highly recommended!
    i like volkswagens
