Results 1 to 6 of 6
Thread: 2015-17 Polo 81TSi fuel.
    Red face 2015-17 Polo 81TSi fuel.
    I am currently using 95 ULP fuel as recommended. Can i use 91 ULP ? This is cheaper obviously, most of my driving is around town, with the odd 1000 km trip. Geriatric driver
    Apr 2017
    belgrave victoria
    No stick with the 95RON fuel you will end up damaging your motor with low quality fuel it says min 95ron on the cap for a good reason
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Pacific Paradise QLD
    98 is even better
    Dec 2008
    Sydney/Canberra
    If past instances are to go by with recent VW petrol engines, 95RON is barely cutting it.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Erskineville, NSW
    Quote Originally Posted by leeming View Post
    It's a no from me.
    The knock sensors will sense the detonation and retard the timing, richen the mixture & reduce boost, so you'll get worse fuel economy and the cost per kilometre will be higher.
    If you want to save a few cents, you might get away with a tank of e10 94RON but again, on a cents per km basis you won't save much.
    Personally, in hot climates like yours, I'd run 98ron.
    Your best way to save on fuel costs is to drive economically and make sure your tyres are inflated properly - 36-40psi.
    Jun 2011
    Larrakeyah NT
    I recently started using 98 ron instead of 95 ron in my 2011 77tsi
    Now getting better performance, better economy, covering extra fuel cost
    + used to get small rattle on startup, now gone.
