BWA Auto
Results 11 to 20 of 21
Thread: VW servicing in Sydney
    wai's Avatar
    wai
    wai is offline Volkswagen Enthusiast
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Bug_racer View Post
    Page 61 of the owners manual clearly says that the ignition switch turns off power to the cigarette lighter and accessory sockets, only in reality they all remain powered up after turning the ignition off. This has been confirmed with the same excuse as above. The report says that if I wanted to change it I would have to do it at my cost. As a service department, they did not even give me a quote for them to do it. Evidently they have no need to do take in any more money.
    Its an ADR requirement and there was a re-call on Polo's that did this .
    I have just been through the list of ADR's and cannot find anything that mentions this.
    Do you know which ADR this is?
    Thanks.
    Edited...................
    Ok, I found it. It is ADR 42/02, General Safety. In particular clause 6 covers this and it states:
    6. CIGAR AND CIGARETTE LIGHTERS
    Any cigar or cigarette lighter fitted to a motor vehicle must be capable of activation only when the ignition or engine control switch is in the “accessory” or the “engine on” position.
    Now the wording states "Any cigar or cigarette lighter", and so would not cover the accessory sockets elsewhere. So, it clearly states that the sockets "must be capable of activation only when the ignition or engine coltrol switch is in the "accessory" or "engine on" position.
    Thanks for making me search for this critical piece of information. I am not having a go at you, it is very tongue in cheek. Without knowing it was an ADR thing, I would not have known where to start
    Now, the requirement was deleted in 42/03. This is done when it becomes common practice and hence no longer needs to be mandated. The deletion of the requirement does not mean that the manufacturer must now do the exact opposite. The reason it was there was because of safety, and its removal does not now make the opposite a requirement. There are many things that were covered by specific ADR's but the ADR was then withdrawn as it have become standard practice.
    Do you know of the ADR that specifically requires the sockets to be powered up all the time?
    Bug_racer is offline Volkswagen Fanatic
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by wai View Post
    Thanks.
    The ADR rule pretty much stated it can only be powered with the key in the ignition . Maybe try calling MVRIC or the RTA and see what they say . Im not up to date with all the ADRs on cars now cause there are so many . Example would be all Touregs had to have mudflaps fitted , like , wtf ??? A lot of red tape with ADRs today and many dont make sense ...
    Bug_racer supports the rebellion of the euro revolution
    wai's Avatar
    wai
    Jun 2011
    Sydney NSW
    I will. On the subject of rear mud flaps for the Toureg, ADR 42 covers that as well. The mud guard must cover a certain portion of the tyre and trajectory of mud/water off the tyre/road contact patch, but I digress.
    It is a matter of safety for the lighter socket as it has a mechanism to grip and hold the lighter element so that it can heat up. If the lighter element get jambed in the socket (for any reason) it will simply keep heating up and there is no way to turn it off without finding a spanner, lifting the bonnet, and disconnecting the battery. Unless you know exactly which fuse protects it, there is no point in trying to locate and read the fuse layout sticker as it would take you less time to find a spanner and disconnect the battery.
    brad is offline Volkswagenist
    Just near Blakehurst
    I too am looking for a good VW service dealer in the Blacktown area.
    Try Trivetts for your warranty issues. I've heard good things about their service department if you wish to stick with a main dealer for servicing too.
    www.carandimage.com The place where Off-Topic is On-Topic
    Adam's Avatar
    Adam is offline Volkswagen Fan
    Jun 2007
    I recommend Jade Auto repair center at Rosebery. I did my last service there, reasonably priced. They even picked up all the spare coins I have scattered on the floor and tiny cracks of the polo (and gave them to me! Can't get more honest than that!)
    I will most definitely head back to them.
    wai's Avatar
    wai
    Jun 2011
    Sydney NSW
    Thanks.
    I should say that the reason why I did not buy the Caddy from Trivetts Blacktown was because they did not respond to my online and telephone call requests to book a test drive. It was some 3 months after I bought the Caddy from NMG in Penrith that Trivetts actually contacted me regarding a test drive!
    Then again, I had great sales service from NMG, but hopeless vehicle service, maybe it is just the opposite at Trivetts Blacktown.
    I did look into getting an extended 3 year warranty (no rush at the moment), only what is covered is a little bit light. The drive train seems to be excluded, and things like paint can be weaseled out of very easily.
    If you tell them the paint has failed, they ask if you used a polish on it. If you say yes, they will blame it on the polish, and if you say no, they will say you failed to adequately maintain it. The same goes for just about all they do "cover".
    Somehow I don't think they are worth that much anyway. Now I remember why I skipped it when I bought it.
    Thanks again.
    Up to you but in my experience the service dept & sales dept don't work closely together at most dealerships. When i was at Toyota we wouldn't let sales staff in the workshop because they were a lying, manipulative pack of scum (apologies to the honest sales people out there).
    Drive train excluded on the Allianz underwritten genuine VW extended warranty? WTF? It was in there the last time I looked - in fact, it's the main part of the warranty.
    Paint isn't covered under extended warranty AFAIK. And you use polish on your paint? My car is 5 years old & I've never used a product called "polish" on it. Quality car wash, clay, quality wax, quick detailer but never polish.
    Smead's Avatar
    Smead is offline Volkswagen Enthusiast
    Oct 2009
    Canberra ACT
    Slightly off topic, I have used Autoglym Super Resin Polish, along with Autoglyms Extra Gloss protection and High Definition Wax, which is all good quality stuff. Its my understanding that most detailers would use a form of ploish too. its good when layered with EGP and HD wax.
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    polish is an abrasive. If your paint doesn't need correction & you don't need fillers then you don't need polish.
    Plenty of info in the detailing section.
    wai's Avatar
    wai
    Jun 2011
    Sydney NSW
    When you look at the PDS for the Allianz policy, there are many loopholes where they can escape on the drive train. For example:
    16. Any mechanical failure caused by a fault that existed prior to the commencement of cover.
    Forget any claim being paid on a drive train claim as if you have had ANY service where you asked the dealer to check out an issue with the drive train, this is effectively establishing there was a fault prior to the commencement of the warranty extension.
    Even when you take this up when you buy the car, the warranty is in two parts. The first is the manufacturer's warranty that commences when the vehicle is bought, and the extension warranty is from a third party that commences when the manufacturer's warranty expires.
    On the paint bit, I don't and would not use polish unless I needed to correct an issue. This is what happened to a colleague where the paint started to flake off (you have seen the cars with what appears to be "sun burn"). Well, no matter which way he went he was knocked out. He was basically told that if he did not use a polish or any other treatment, he was not maintaining the vehicle adequately, and if he did use a polish or anything else, then he would have to take the matter up with the treatment manufacturer.
