BoschAutoShop
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 52
Thread: Suspension Recommendations
  1. #31
    firdausasri is offline Volkswagen Fan
    Kuala Lumpur
    I'm getting my H&R monotube coilovers (hopefully it comes with shorten drop links) and will get it installed plus corner weighting and geometry corrections soon. Will do a review soon
  2. #32
    vwthunder's Avatar
    vwthunder is offline Volkswagenist
    Sep 2006
    Anyone have any info on a front swaybar upgrade , how it feels etc.
    Done a track day and the car seems to understeer even with the rear bar on its hardest setting. Thinking on trying a front bar
    MODS- TOO MANY
  3. #33
    pog
    pog is offline Volkswagen Fan
    Jan 2010
    I believe noone has a FSB.
    This is a decent read on FSB feedback: http://www.vwwatercooled.org.au/foru...ion-41024.html
  4. #34
    VWindahouse's Avatar
    VWindahouse is online now Volkswagen Fanatic
    Feb 2007
    Brisvegas
    Hey Troy,
    done a couple of recent track runs on a fairly elevated track which really shows up all the flaws of a fwd car.
    The second run I had the rear on medium and the front changed also to medium from soft and I think it's the closest i'm going to get to a completely neutral balance on the the Devil. Never before seen so much turn in and no understeer. And the most grip i've ever had from a takeoff and cornering. I also have a Forge strut brace and a Wiechers steel lower brace so the front end is very tight now especially with the sway on medium. I dare say If I went with damper adjustable coilovers and dialed a slightly harder setting on the fronts it would be go cart like experience. Oh and from what i've read the light weight rims help with turn in and feedback also. It was fun disposing of a few Golf R's too
    My Polo GTI project thread "Little Red Devil"
    Custom Code Phase III
    Billet Turbo Ceramic ball bearing hybrid turbo
    More fun to come...
  5. #35
    vwthunder's Avatar
    Sep 2006
    Quote Originally Posted by VWindahouse View Post
    Hey Troy,
    How is the Whiteline rear toe correction kit
    MODS- TOO MANY
  6. #36
    Feb 2007
    Brisvegas
    The wheel alignment printouts say they're a winner!
    More fun to come...
  7. #37
    noone's Avatar
    noone is offline Damned BlueCollar Tweaker
    Jan 2009
    blankedy
    front sway can add a lot of traction and make the ride stiff. I'm not sure of the direct difference between stock and the fsb as I had coilovers and a bunch of other bits done at the same time.
    If you are keen, I'd suggest looking towards a LSD and sticky rubber for the front end.
    The much cheaper FSB can certainly help keep more weight on the inside wheel.
  8. #38
    kaanage's Avatar
    kaanage is offline Volkswagenist
    Oct 2010
    Melbourne, VIC
    Unless you have enough body roll to cause serious camber issues, an anti roll bar does the opposite - you lose grip with the extra roll stiffness as weight gets transferred from the inside wheel to the outer one.
    Unless I've misinterpreted your comment and you are talking about using an aftermarket front antiroll bar that has lower stiffness than stock.
    What greater roll stiffness does give you is better steering response.
    Resident grumpy old fart
  9. #39
    vwthunder's Avatar
    Sep 2006
    Think I will go to pedders tomorrow and order the Toe Correction and hold off on the Swaybar for a bit
    MODS- TOO MANY
  10. #40
    Stuwey's Avatar
    Stuwey is offline Volkswagen Fan
    Don't want to sound rude, but I think you need some more practice in a powerful FWD. Less is more!
    | APR | Recaro | Bilstein | H&R | O.Z. |
