Originally Posted by
metalhead
Sorry, no idea on the tyre diameter affecting your electronic devices, I don't have any of those! Looks as though Gary is saying it will be ok?
My Longacre durometer arrived this morning (pretty impressive, ordered from Raceline Motorsport Racewear on Wednesday). My "soft semislicks" measure between 80 and 85 on the durometer, my street tyres around 70... So do I need to declare these semis dead?
Just confirming, 80 to 85 inside, middle and outside across the tread, 3 to 4 spots around the circumference? Rocking the durometer?
They should be 60's when stone cold and maybe high 50's at today's ambient.
If there is any build/pick up you should scrape it off to check the tyre under it.
Rather than just chucking them out you might want to consider skimming/dressing them a couple of mm's, it may just be the surface that's gone hard. You could just skim a few spots with a heat gun and a paint scraper, that will tell you if doing the whole tyre is worthwhile.
Gary
