The 288x25 I believe are what you want but you would do well to give Greg at GSL Rallysport a call locally and see what he can do for you.
Once again I need assistance from 'the wise ones', this time I need to identify replacement the front and rear brake rotors.
Current I have non standard 'Dixcel' HS Type 131 3035 slotted near the end of life. They have been quite ok, but I have no comparison as the 'Dixcel's were fitted when I got the Polo.
Please no one just say 'do a search'. There are always result posts that leave out so much detail and omit pricing guides, a search that ends up being more of a puzzle than a help at times.
Since I intend to order Volkswagen Golf IV 1.8T > Search > ES125 > ES#125 Stage 1 Clutch Kit - Steel Flywheel (14lbs.) - ESR198031S1 I could also put the rotors on the same order so I can also replace the front brake disc rotors too. As I have slotted now and would go the crossdrilled and slotted.
But while I'm at it i noticed they have these Volkswagen Golf IV 1.8T > ECS News > Volkswagen ECS GEOMET Coated Rotors and http://www..com/Volkswagen-Golf_IV--...OEM/ES2189954/ but which part suits our 9N Polo Gti?
Or is there better brake suppliers and options for rotors elsewhere? Links and please idenitfy any translation for the specific overseas VW or Audi model that is a straight fit for the 9N Polo Gti My 2008.
Cheers and thank you oh wise ones ! Al
MY08 Polo GTI - GIAC, Milltek, Forge, KW... Winton PB: 1:42.8 For Sale: http://www.vwwatercooled.com.au/foru...ods-84830.html
Yep, Greg is a great guy and really helpful plus he knows his stuff.
In regards to rotors, I get flamed for this often but if you are after performance, stick with plain rotors. If you are after looks, then go cross drilled and slotted![]()
All DSG Owners MUST read this. VW Apologises for DSG Problems in China, Russia and USA. Why not here?
~500,000 defective units in China alone..
I bought slotted Brembo rotors off ECS back in 2009, and they are still going strong. They are the same size as the MK4 GTI.
Thats right they are the same, only the pads are different.
Technician before the internet came about
Audi/VW/Porsche Factory trained tech 24+ yrs exp
I contacted GSL Rallysport and on their recommendation ordered RDA 7198S front rotors. Waiting for them to be delivered, thanks for the posts and responses one and all.
Are these front rotors difficult to instal, anything to avoid or watch for? Do not need pads as Jimmy did them recently ............ Cheers Al
There is a guide in this section (by Blitzen?), have a search.
This car has been out for well over 6 years now, and everything that has been done to it is covered in this section. Trust me, a search will find it, and yes, I did a DIY front rotor guide, way back in October 09. Look up 'Changing Polo GTI Front Brake Rotors'.
Gentlemen, Blitzen thanks very much. I have now used the search option and found your excellant post with pics. Cheers Al
