Page 37 of 48 FirstFirst ... 27353637383947 ... LastLast
Results 361 to 370 of 476
Thread: Louis19's Build Thread
  1. #361
    nsw
    these guys make beautiful thin walled MAF bodies and honeycomb MAFscreens if your interested:
    Mass Air Flow Housings | MRP Manufacturing
  2. #362
    Feb 2014
    Gold Coast, Queensland
    Thanks mate. These sensors come with their own flange which you can just weld to whichever size pipe you’d like dependant on the setup. I’ve just got to cut off the stock plug and wire it onto the wiring loom.
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  3. #363
    nsw
    nice and simple. yeah I didn't think I could see a traditional MAF body in there.
  4. #364
    Feb 2014
    Bit of finalising bits and pieces today before it goes to the exhaust shop on Monday for the dump pipe and external wastegate piping. MAF wiring done, checked over all the IC Pipe work, bolted bumper back on and finished off coolant hosing.
    Got my partner out to give me a hand to make sure we can push it up the driveway so that it’s ready first thing Monday morning when the tow truck driver arrives. Also the new number plates arrived so they are now on, they should provide some good laughs on track.
    Exciting week ahead
  5. #365
    Nov 2012
    WA
    So you've notched the rear bumper to get the rear muffler higher
    What's the aim, managed to get a big muffler in there to stop drone?
    08 9n3 Polo GTI
    Mods: heaps
  6. #366
    Feb 2014
    Quote Originally Posted by rgvlee View Post
    Yeah that and I just liked the positioning of it being higher up so from behind when following the car the muffler isn’t seen as much rather than sitting lower down. You couldn’t fit a bigger rear muffler width wise than what it is now.
  7. #367
    Feb 2014
    What a week! Car went to the exhaust shop first thing Monday morning, came home late Friday afternoon. In the end we had clearance issues with the wastegate being too close to brake lines for our liking for we had relocate it to onto the exhaust housing of the turbo. It meant the turbo had to come back off but it’s worked in our favour for room and ease of fitment. Once the car was back home, a few things needed adjusting to suit the relocation, along with making up a heat shield to seperate the brake reservoir from direct heat.
    Yesterday was just a quick crank to get some oil pressure then turn it over to make sure it would start today when we loaded the base tune file which was done today. After cranking it over today, it was ready for its first time to move under its own power since the rebuild.
  8. #368
    Feb 2014
  9. #369
    nsw
    love it man. That looks awesome. God you must be itching to get your boot into it.
  10. #370
    Feb 2014
    Quote Originally Posted by sambb View Post
    Thanks Sam. You bet I am haha. Sorting out a couple little things in the base file then I should be able to clock some kms up on it so we can start to dial it up
