Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 114
Thread: Fastest polo in Aus
    jasn78's Avatar
    jasn78 is online now Volkswagen Fanatic
    Dec 2006
    Quote Originally Posted by clicht View Post
    2 questions if you dont mind:
    1. what spring/ shims are you using on your 008, and
    2. when are you migrating to a larger turbo
    using just the yellow spring no shims
    as for larger turbo been thinking alot about it but I now want to see how low Ican get with a k03
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time. :emo_baghead:
    VWindahouse's Avatar
    VWindahouse is online now Volkswagen Fanatic
    Feb 2007
    Brisvegas
    Crazy stuff Jason!!! Seriously well done, I know you've been chasing this for years now. And on 16" streeters too! Anyone in the market for a set of 17" Enkies
    My Polo GTI project thread "Little Red Devil"
    147.1kW 376.4Nm atw Dyno Dynamics, 156.3kw 348.6Nm Dynapack Hub Dyno
    13.935 1/4 Mile
    Custom Code + K03s FTW
    Gambit's Avatar
    Gambit is offline Volkswagen Fan
    6r polo gti should beat it easily with fewer mods ?
    kaanage's Avatar
    kaanage is offline Volkswagenist
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by jasn78 View Post
    Now I do expect and demand this time be beaten by a couple of people on here(Yes Vwthunder and vwindahouse. I am specifically calling you 2 out)
    What about Eddy and his little blue girl?
    ---------- Post added at 08:05 AM ---------- Previous post was at 08:04 AM ----------
    Quote Originally Posted by Gambit View Post
    Ooh, now there's a challenge - anyone in mind who'll front up? The APR car, I'm guessing but does that have fewer mods?
    ---------- Post added at 08:10 AM ---------- Previous post was at 08:05 AM ----------
    Quote Originally Posted by VWindahouse View Post
    Tyre diameter/profile shouldn't have any effect in a drag except for weight (taller profile/smaller wheel is probably lighter) as long as the widths are the same. The impressive thing is that the Proxes 4's that Jason used have a UTQG wear rating of 300!!
    vwthunder, if you can be bothered changing your brakes back to stock for a drag run, you can borrow my 15" Team Dynamics with the Advan semi slicks for the fronts and get 2 space savers for the rears.
    Resident grumpy old fart
    jasn78's Avatar
    Dec 2006
    Quote Originally Posted by kaanage View Post
    What about Eddy and his little blue girl?[COLOR="Silver"]
    Eddy has run his down the quarter before and while I know he could beat me he has always had problems on previous runs.
    ---------- Post added at 08:21 AM ---------- Previous post was at 08:20 AM ----------
    mate go for it then thats half the point of this thread is to get people's arses into gear and get some times out there but until then I still hold the record
    ---------- Post added at 08:23 AM ---------- Previous post was at 08:21 AM ----------
    the thing it defintley does help with is when running 25psi it gives me alot more contact patch
    vwthunder's Avatar
    vwthunder is offline Volkswagen Fanatic
    Sep 2006
    Haha thanks greg, at the moment focused on Winton and the dyno day
    I would be worried that i would break something on the Quarter if I ran semi's. A little polo is not a drag car, still got the stock clutch too
    MODS- TOO MANY
    Feb 2007
    Brisvegas
    That's what I'm worried about. Ive got 215/40's stretched over 8" so very low profile.
    13.935 1/4 Mile
    vwthunder's Avatar
    Sep 2006
    How do you go with the 215's
    MODS- TOO MANY
    jasn78's Avatar
    Dec 2006
    Quote Originally Posted by vwthunder View Post
    Im with you mate on the breaking something with semis I know Kai went through numerous cv joints party cause of this reason
    Sharkie's Avatar
    Sharkie is offline Supporter of VWWatercooled
    Nov 2007
    Well done Jason!
    I'll let you hold on to that title for a bit longer ..... when I'm done my mods and making 200wkw then I'll have a go .....
