BoschAutoShop
Results 1 to 10 of 15
Thread: Dilemma... - installing lowering springs
    insanekiwi's Avatar
    insanekiwi is offline Volkswagen Enthusiast
    Jul 2007
    Auckland, NZ
    Hi guys,
    I am a bit mixed here... I have H&R 35mm lowering spring kit with me. Well sitting right next to me.
    My friend who has been in numerous sport cars, has just driven my car. He was well impressed with REVOed Polo GTI. He did not expect that at all.
    I've told him about the plans for the upgrade that's booked next week.
    He said the suspension is really good as standard, just hard enough for track days, and enough for daily commute drive. He really did not think it was good idea to just stick H&R springs in without replacing shocks.
    For those ones who have replaced 'springs' only... what are your thoughts?
    I mean if I don't lower it, I won't need to worry about drive ways, etc.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    VW GTI's Avatar
    VW GTI is offline Volkswagen Fanatic
    Jan 2008
    1) that '35mm' spring kit is 35mm lowering from the normal Polo. Which means 20mm from the GTI. This means driveways are not as much of a problem as you'd think.
    2) The GTI also has different shocks to a normal Polo so they should cope.
    I haven't done it to mine yet, it's on the radar for sometime soon. I have done some research though. Would be interested to hear from a few with it done too.
    Timbo's Avatar
    Timbo is offline Volkswagen Enthusiast
    Nov 2006
    I originally believed the biggest problem with the Polo was under-damping, so I fitted Koni adjustable shocks, and have been very happy with them.
    However, recently I succumbed to springs, and installed the Eibach Pro Kit. The transformation is significant, and I would thoroughly recommend them. The car feels so much more 'planted' -- the ride is firmer, but by no means harsh; in fact, it feels much more coordinated, with less pitch and dive. The Eibachs seem perfectly tuned to the Konis; indeed, I understand that Eibach make the springs in the Koni Sports Kit
    I wouldn't lower too much unless you are privileged to drive on billiard tables!
    SoVeReIgN's Avatar
    SoVeReIgN is offline Volkswagen Fanatic
    Nov 2006
    Generally always a bad idea to only do one or the other - The damping rate of the shocks needs to be matched to the spring rate.
    insanekiwi's Avatar
    Jul 2007
    Auckland, NZ
    Thanks for the feedbacks so far.
    I clearly understand shocks and springs are best match. I can't afford both at the moment. Have springs already and not sure now whether to get it fitted or not.
    Are you sure 35mm lowering is from original Polo height? It's hard to believe as the spring kits were designed for Polo GTi specifically.
    Jarred's Avatar
    Jarred is offline Dub Crazy
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by SoVeReIgN View Post
    x2.
    You can mix and match. but if you do you're asking to blow a shock or something similar. so, really not worth it.
    You've got springs now, just save up for adj. or lowered (ie matched) shockers. That way you'll have time to save up for a few trackdays with the current suspension, and then once you swap over to the new shocks and springs, and do some more trackdays, you'll be able to really feel the difference!
    IMO >> save for shocks.
    i like volkswagens
    VW GTI's Avatar
    Jan 2008
    Quote Originally Posted by insanekiwi View Post
    Check the model numbers against the kits for the TDi and 1.4 or whatever it is. They are the same.
    ryan_GTI is offline Volkswagen Fan
    Nov 2006
    Brisneyland
    yeah what others have said, hold onto the springs - save up abit more for aftermarket shocks then do it all in one go.
    do it right the first time.
    insanekiwi's Avatar
    Jul 2007
    Auckland, NZ
    It's 35mm all around for GTI. GTI specific springs not for other Polos.
    Maybe I might just sell the springs....... I don't know if I want to spend that much for shocks + the springs + installation...
    Anyone interested in springs?
    99gti's Avatar
    99gti is offline Volkswagenist
    May 2007
    NSW
    Bah humbug. You can install them and you probably will still get a slight improvement in handling and you'll have a much more agressive stance. It will cause the standard shocks to not live to their expected life - but as long as you are aware of that prior I say do it!
    I've had numerous cars with lowered springs and they were fine. As long as you arn't expecting coilover performance from them then I think you should be happy with the end result.
    In all the cars I've had I've never had a shock blow out, but I havn't lowered it to a stupid height either. This would be the kind of result I'd expect from chopped spings.
    Are they TuV approved? Ask H&R if they are suitable to use with the standard shocks.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
