Topping it up once with water would be OK.
hey guys ...my coolant warning light came on last nite and stayed on....i checked the level and its right on minimum do i go out and buy coolant or topp it up with water?
thanx
2001 Bora 4 Motion Sport now used by the Misses
1998 Seat Ibiza Cupra - Current project will benefit from below
1999 Seat Ibiza Cupra - Sadly now being dismantled due in part to number one son
2006 Polo GTI - Absolutely loving it
Read your owners manual!
It will suggest a small amount of water or go buy yourself a bottle of OEM G12 or G12+ coolant for top up purposes.
But it could be indicating something else, have you seen any leaks / puddles in your Garage?
2012 MY12 VW Jetta 118TSI Comfortline + Sport Package + Leather + some extra goodies... (Reflex Silver)
More than likely just warning you about the level. Same thing happened to me a few weeks a go. I checked -- no leaks, but level just below minimum -- topped it up with coolant and I've had no lights since.
That sensor must be very sensitive, because mine was just below the min mark.
My coolant light came on with the level down a bit after about 30000ks.. guessing the polos just spit a bit of coolant out over time as I havent seen any puddles/ leaks
NO! please do not topping it up with water!! go buy a G12 or G12+, mix it with distilled water and top it up to your polo
This is what you need, i have instruction at the back
2013 4Motion "BLACK BEAR"
http://blackbeartiguan.blogspot.hk//
I had to top up within the last week as well. Coolant less than $20 from VW. Must be the season for it .....
A little bit of distiled water never hurt anything - But if you have to put more than a couple of hundred mils go with G12. (IMO)
Just remember that the coolant also has the job of lubricating your waterpump, it's not just a anti-freeze/anti-boil and anti corosion green stuff (or red).
