Results 11 to 20 of 21
Thread: Control arm bushes Polo GTi
    polomatic is offline New Dubber
    Jun 2012
    Braddon, ACT
    Why 'NOT polyurethane'? So solid bushes are the way to go? Any major price differences?
    noone's Avatar
    noone is offline Damned BlueCollar Tweaker
    Jan 2009
    blankedy
    To hard, encourage vibrations through the chassis.
    You mean what's the cheap option? Buy the Seat ones from the Uk like Awesome GTI.
    Jmac's Avatar
    Jmac is offline Factaraidh Teignoelaiche
    Aug 2007
    Brisbane.
    As already mentioned i can supply them here is Aus unless im too dear
    Too hard, havent had any complaints about feedback even though theoretically there should be, i fit them to the whole 9N range, never had a drama and you wont be fitting them as often either, another upside. The voided ones just dont last. Everyone has their take, thats mines
    Jmac
    Technician before the internet came about
    Audi/VW/Porsche Factory trained tech 24+ yrs exp
    kaanage's Avatar
    kaanage is offline Volkswagenist
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Jmac View Post
    You can make me the exception, Jimmy
    I find the SEAT solid bushes transmit too much vibration through from the drivetrain when tooling around at 1000rpm - this won't be an issue for non-diesels as they never operate under any load down there.
    They'll be coming out when I get the camber plates installed, if I can successfully make up inserts for the voided bushes.
    One of the other GTi owners got some newer spec bushes that had 4 rubber webs rather than 2 - I think it's buried in the "what did I do today" thread.
    Resident grumpy old fart
    noone's Avatar
    Jan 2009
    blankedy
    Not too expensive Jim, just very cheap from OS... I should do more to support our local heroes, sorry.
    the vibration was in relation to the nolathane ones, not the seat Rubber or whatever they are.
    Having moved from the Whiteline ones to the Seat ones, be wary of making the ride too rough. I did a number of mods at the same time, so there may be little difference, but I'd lean on the soft side where possible.
    xc17ed's Avatar
    xc17ed is offline Volkswagen Fan
    Jan 2010
    Hit up Jmac, easiest transaction I've made and by far.
    2007 MY08 VW Golf MKV R32 Blue 6M 3-Door
    2006 9N3 VW Polo GTI White 5M 3-Door
    GTiPilot's Avatar
    GTiPilot is offline Volkswagen Fan
    Mar 2012
    Copacabana, NSW
    Hi,
    Just wondering what's involved in doing these yourself? I've got a set of the seat ones which look so much better than the stock ones. Is a press necessary or just quicker to use one?
    I'm up in Darwin.
    Cheers,
    Scott
    Red 2006 Polo GTi : Forge Splitter - TIP - ITB - Forge Front & Rear Strut Bars - Dash Cubby - Fumoto Valve - Full Milltek Exhaust - PD160 Intake - K&N Panel - ECS Stage 1 Clutch - Seat RCA Bushes - APR Stage 1+
    blackbetty is offline Volkswagen Fan
    Aug 2009
    Im curious about this too i.e. how to replace them. im sure i have a dodgy one on the fron left so once i get under there and verify, i'll be after replacements.
    do whiteline make a kit for these? i havent checked their website
    06 Polo GTI
    standard ECU, wheels and everything else | K&N Panel filter | PD160 intake tube and trumpet |Shell Helix | Marangoni Zeta Linea tyres
    gavs's Avatar
    gavs is offline Gavs, Sir Gavs... Moderator VWwA Super Moderator
    Jun 2008
    Ringwood, Victoria
    No you don't need a press, you can do it with a decent bench vice but a press makes it much much easier.
    You do need to fully remove the lower control arms to do it.
    All DSG Owners MUST read this. VW Apologises for DSG Problems in China, Russia and USA. Why not here?
    ~500,000 defective units in China alone.
    kaanage's Avatar
    Oct 2010
    Melbourne, VIC
    You don't need to remove the control arms if you remove the consoles that house the bushes from the subframe. You do need to replace the stretchy bolts as indicated by Jimmy in the SEAT bush thread.
    Quote Originally Posted by blackbetty View Post
    They make polyureathane ones via their sister Noelathane brand. The twisting that takes place when the control arm moves (the geometry means that the control arm doesn't simply pivot on these) makes these less than ideal.
