Should be a sticker on the B pillar or in the boot with the build date on it. Be aware with a diesel it needs a good hot run often or the DPF will soot up and they arent cheap.
Not a car for a tootle to work each day
It must also be filled with VW approved 504/507 grade oil VW use Castrol professional III at huge prices. You can buy stuff like Penrite Enviro+ or a different Catstrol Edge for a lot less and supply your own at oil change time.
