Originally Posted by
craig_the_german
I have an electric brake controller fitted to another vehicle. You'll need a power supply from the battery and a brake signal usually taken from the brake pedal switch. You will also need to look at where to fit the module (mine is behind the glove box but is not a Golf so check for space)and mine has a control knob that fitted into the console. Redarc TowPro or TowPro Elite come highly recommended (mine is a Towpro) The only issue I can imagine would come if connecting a brake controller confused the onboard electronics and threw errors.
