Results 1 to 7 of 7
Thread: MK6 2.0 TDI DSG - timing belt / cam belt kit service interval and parts
    Dec 2009
    PERTH, WA
    My Golf has only done about 45K, and my owner's manual says that the timing belt is due at 120K or 8 yrs (assumed at 15K per annum), so I need to get this done pronto. To some surprise I've read here from 2015 Timing belt interval on 2012 mk6 tdi? of the new interval:
    "for all vw passenger cars and has been like this for about 5 years now. forget what the service book says as they are all different and for europe... VW AUS state the 105k / 7 years petrol and diesel ".
    A bit late in the day to contact a VW specialist, so I thought I'd ask here...
    1. Can anyone confirm if a MK6 TDI 103kW has an updated schedule for the timing belt change from 120k / 8yrs to 105k / 7 years?
    2. The timing belt change prices vary massively. I suspect it's because of the differences in what was actually changed, such as belt, idlers, tensioner(s), water pump. I've seen kits that include from just two parts to a whole swag, see here: ECS News - Timing Belt Service Kits | VW MK6 Golf TDI | Beetle TDI Given my car has only done about 45K, should I do the whole shooting match, or should I be more selective: belt and water pump then do everything in an "ultimate" kit the next time? Or is is better, for the sake of a few hundred dollars extra in parts - "just do everything" at each belt change regardless of KMs.
    With tensioners and idlers, I would think that with just 45K on them, they should last at least until the next belt is due. Water pump? Not so sure. With my ol' Subaru Forester, I left the water pump till the second timing belt at 185K Kms and 14yrs and there were only slight signs of a weeping leak.
    3. What are the VW part numbers from the kits that others have had installed. If I get a few quotes, then at least I can better compare what is planned to be changed, or specify exactly what I want done.
    Muchos grassos
    Zano - PERTH, WA
    MY09 Golf MKVI TDI 2.0, DSG, Sports Pack
    Apr 2017
    belgrave victoria
    On my old mark 6 tdi i had belt done at 105k not the water pump tho car still in family and at 150k now no issues so far
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Dec 2008
    Sydney/Canberra
    The service schedue is retroactive, so it's 105K/7yrs for everything, regardless of age.
    You're always better off doing everything in one go. I'd look closely at the poly-V belt as well, as they tend to deteriorate prematurely on the TDI CR motors.
    You're better off using a parts supplier who can look up what you need off your VIN, as there's small variations in pulleys and belt lengths.
    Water pump is prone to leak on the TDI CRs, not to mention that the impellor is plastic. Stick with the plastic impellor'd ones, as the metal ones will chew through the water jacket if the bearings fail.
    Total price for the 105K service (remembering it'll be due for the engine oil and filter too), from an independant will be anywhere between $1,000 and $1,500. Depends on the labour rate mainly. Anything under $1K, you'd have to question the quality of the parts. Use nothing less than OEM European stuff.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2009
    PERTH, WA
    Quote Originally Posted by Kachingg View Post
    Do you remember roughly how old the car was at the time?
    Zano - PERTH, WA
    Dec 2009
    PERTH, WA
    Quote Originally Posted by Umai Naa!! View Post
    I've read some other posts slagging off about the plastic impellored pumps, because they can break up or dissolve away...??
    Your costings of the 105K, is that basically for the timing belt and oil/filter change?
    Zano - PERTH, WA
    Dec 2008
    Sydney/Canberra
    They only break when you don't treat them as a consumable. They need to be replaced as often as the timing belt.
    As for costings, yes.
    '01 Beetle 2.0
    Adelaide hills, SA
    Quote Originally Posted by Zano View Post
    There is no problem with the plastic impeller water pumps in the current engines. The advantage is that when the bearing fails no damage is done to other engine components by rotating plastic impeller.
