Would recommend the RCD330. I installed one in my 09 Comfortline. Plug and play, works with steering wheel controls, has Apple CarPlay and built in bluetooth and microphone so a seperate module isn't necessary. Got mine from Aliexpress for a steal. There's a couple different versions around though. Make sure you get the one with the "app" button as this is apparently a later revision.
2009 Mk6 Golf 103TDI- Silver Leaf
You want the RCD330+ programmed with either carplay or the android equivalent. The RCD330+ has the bluetooth module and mic built in. You can get em for under A$300 on ebay. It has no CD player but who really cares these days...
Look for the one that has factory carplay as opposed to being upgraded afterwards. What Seebe said.
Yep, all that. For older cars you get a fancy colour screen, bluetooth and CarPlay/AndroidAuto all in one unit very cheaply. You are now reliant on your phone for mapping which could be a concern, but data is cheap! (and there are apps with local maps anyway if needed).
If it was for one of my cars I'd mod in the rear USB port rather than having a cable hanging out the front, but otherwise it's a pretty bloody good upgrade... and did anyone mention it's totally plug and play with only 4 screws and the stock cables.
Not sure if there are any CANBUS issues on the MK5, something to double check.
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
I've not done this upgrade personally (yet) but have done plenty of RNS and other head unit installs for myself and others. It's pretty idiot proof, four screws and the quadlock plug, bam that's it.
As for which model, read the other thread (which I can't link to at the moment because I'm on my phone, but I'm sure someone will help me out...) to get the recommended one.
edit: This link: Replacing RNS 510 with RCD 330+
RNS315? There maybe a few cheap ones of these floating around on fleabay. Small screen but feature packed otherwise.
Cheers dave
Try a wrecker for the interior bits - GMS Spares (02) 9774 5184.
Radio unit as above.
Speakers - I just purchased Focal IFVW to upgrade the front, should arrive tomorrow, but look promising!
2007 MY08 VW Golf MKV R32 Blue 6M 3-Door
2006 9N3 VW Polo GTI White 5M 3-Door
