Page 138 of 138 FirstFirst ... 3888128136137138
Results 1,371 to 1,378 of 1378
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #1371
    If you have no power under 3,000rpm and you are very lucky it might just be the waterpump / supercharger clutch mechanism. Another reasonably common issue with these engines. The fault means the supercharger does not engage meaning the car is very low on power below 3,000rpm.
    Fault code P10A9 (not that expect the dealership will tell you the fault code)
    If the engine wont physically go past 3,000rpm no matter how much you try, then its going to be in a limp mode status which seriously reduces power and RPM limit in order to allow you to get the car home/mechanic.
    Quote Originally Posted by dribs View Post
    ...driving today up the M1 to central coast (1hr in a 1.5hr drive) - felt lost of power. Sluggish to climb up hills and wouldn't go past 3,000 RPM - it wanted to stay in Gear 7 for everything lol. Anyway, got to my destination, decided to let her rest. My heart stank basically.
    Started her back up after 2 hours and same symptoms - no change. No engine light yet on dash.
    Managed to get home after driving 2 hours with no problems - though still sluggish on power as before and 3,000 RPM limit - cruising at 110km/h. My intention was to get the drive down and go straight to the dealer basically.
    2017 Ford Fiesta ST
  2. #1372
    Sep 2010
    So I got a diagnosis from the dealer today. The report said the fuse was blown for the magnetic clutch and had to go ahead to check wiring. If wiring is okay, then the magnetic clutch / water pump needs replacing.
    From what I understand from the report, the wiring is okay - so the waterpump needs replacing basically - says "gasket bolt drives drive for supercharger".
    Total cost all up will be just short of 3k.
    A sign of relief for now. So its the waterpump supercharger pump issue it would seem? Expensive fix though - about $2.3k for the job, which from what I read is a difficult job anyway which sounds about right?
    Thankfully much better news than a cracked piston..
    MY11.5 118TSI - Reflex Silver Metallic, RNS-510, RVC + Park-Assist.
    Delivered March 2011 and on the road
  3. #1373
    Genuine part is $950 or so. So 2k for labour. 03C121004J - Water Pump - Audi & Volkswagen 1.4 TFSI/TSI– VAGPARTS Australia
    $300 for a good quality aftermarket unit. TOPRAN Water Pump 113 791 | Run Auto Parts
    You could certainly save some cash by having the job done by a VW specialist mechanic instead of the VW dealership as you are paying absolute top dollar for labour and having to buy genuine parts.
    2017 Ford Fiesta ST
  4. #1374
    Jan 2019
    Good luck Dribs.
    When my water pump failed in 2018, I paid about $1500. Parts and labour. If you're really lucky it may only be a fuse (though I'm sure the dealership would have tried that?)
  5. #1375
    Sep 2010
    Quote Originally Posted by YoYoYo View Post
    Good luck Dribs.
    Was all fixed on Friday and good to go since! Was the pump, labour was $1.5k and part was $800 @ the dealer.
    As per Lucas_R I could've gone across the bridge for an indie VW dealer, but I needed a ride and thankfully can sorta stomach the cost to fix at the dealer.
    Hopefully the car can go for another fair years :pray:
  6. #1376
    Apr 2023
    Hi everyone,
    At a bit of a dead end with my VW Golf, so thought I'd try here for some advice. I recently purchased a 2011 Golf Cabriolet 118TSi from a private seller, car is at 124000km approximately. Car had come with RWC, rego and a full service history, regularly done at VW (most recent ones being Ringwood VIC). It was driving perfectly for about a month, after which the car kept saying to check oil levels so I took it to a local mechanic who diagnosed the issue to be the oil sensor needing replacement as it had reached 'end of life'. There were also misfires detected in cylinders 1 and 4, but the mechanic said they had fixed this issue. The car was great after that for about a month, after which the engine light came on as soon as I re-fuelled. I have only ever used 98 fuel. I thought it was a fuel cap issue (as diagnosed by the internet) given the light came on as soon as I started the car after refuelling. I tried to fix it but it would not go away, and the next day the car essentially went into 'idle mode', was jerking and would not accelerate/was resisting. I took it to the mechanic again, who first said it was a fuel pressure issue, and has no come back and said the 'timing chain has stretched', and the cost to repair will be $2-3k, as well as $250 for the services he's already done (diagnosing the issue etc.). I am a student so I absolutely do not have the money for this. I have done some research and found this forum and others, where people have had similar issues and had VW cover the costs. I have contacted the customer service, who were incredibly unhelpful and basically said because the car is out of warranty I have to pay and to contact the dealership. I contacted the dealership the previous owner went to and they said they can file for a goodwill claim but it is unlikely that it will get approved given the age of the car. They told me to bring the car in so they can diagnose but I live over an hour away so I was redirected to my local one. I spoke to two different people at my local dealership who were both discouraging, saying Goodwill will not be approved most liekly due to the age of the car, regardless of the low kms. They said they can still apply on my behalf, but the issue needs to be diagnosed first and for that they need to 'strip the engine' which will be about $940. This fee will be waived if Goodwill is approved but if not I will have to pay for this, and to also put the car back together. I don't undertand how they can basically tell me to commit without giving any guarantee, as its essentially a gamble for me where if Goodwill is not approved (which is looking unlikely) I will be out of pocket $2-3k regardless. One of the people I spoke to at the dealership said that if I can 'build a case and give strong evidence' regarding this issue that maybe I might stand a chance. I find this absolutely ridiculous as why am I having to prove this fault when VW is aware of the issue in these engines. I really love the car and it breaks my heart thinking of selling so I'm really hopignto get some clarity on the goodwill claims, or what other way Ican get VW to cover it. The car still has plenty of kms left before it reaches the end of life of the engine according to the ACCC, so its baffling to me that this issue has occurred so early. I can see now that this is a common issue with this engine, and I don't understand why VW is being so difficult, as i can see in the past they've bveen quite helpful. I have also taken the advice of some people previously from this forum and emailed people higher up in the company, e.g. customer experience head, managing director etc based on the little information I could find.
    Any advice on this matter would be highly appreciated. As mentioned, I'm a student and admittedly not the most well-versed with cars, so would love to know what you guys think. I'm also highly reliant on this car for work as I'm a mobile tutor and have already lost a client due to not being able to make sessions as I haven't had a car. The car is currently booked with the dealer foe 8th May, and I don't know whether I should take it to them as I have no guarantee on whether I will have to foot the bill or not. Not sure if I want to roll the dice. Any help would be so so appreciated. Thanks in advance!!!!!
  7. #1377
    Jun 2007
    Quote Originally Posted by AEMOMEMO View Post
    Hi everyone,
    Hate to be the bearer of bad tidings, but the car is 12 years old, I can't see any way VW will cover this, so getting a VW dealer to tear it down will almost certainly be throwing good money after bad. Also can't see ACCC doing anything at this age.
    Others have replaced their engine with a second hand one from a wreck, but not knowing if the replacement engine has had a rebuild means the next step would be to sell the car, before the replacement engine fails. Problem is, most people do their research and know about the issues with these engines so the pool of buyers is small.
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
  8. #1378
    Dec 2006
    Kilsyth, VIC
    It's a tough one, these cars are getting on in years and goodwill is less and less likely/common, even more so when you're not the original owner.
    I'd like to think that a compression test (and maybe boroscope image) would be enough given ***everyone*** knows about this issue! The tear down is likely a policy, which I understand from a diagnosis point of view, but I'd like to think an exception could be made when it's clear as day to anyone who knows these engines what the issue is. Even if it's just for the purposes of lodging the good will claim.
    You could try writing to the head office and suggest this compromise, at least for the good will claim, although it's worth pointing at just how many vehicles have been fixed under good will and that it's a well known fault. Be polite and see where you get to. Even part coverage of labour or parts would be a step in the right direction!
    There is a market for rebuilding these engines, if you were lucky you could find one with the uprated pistons or a CTTH variant to drop in, but it's going to cost you somewhere in the $5k - $8k (ish) range on a good day.
    The only good news is that the failures seem to be (mostly) fixed by the later pistons... but it's a gamble. Do you fix it and move it on, or fix it and pray to the car gods for the best??
